Crikey mate, that's a curly one.  It will vary hugely depending on how often the bike's been worked on.. The bolts and screws holding the body  work alone can take from minutes to hours to get out if it hasn't been off for a long time. The rear suspension bolts can be mongols. Exhausts..  so many things could be seized up.. If it was all in good order and been apart and kept greased I'd say six hours would be about minimum I'd quote, hoping it was only going to take four. If there are problems though it could easily turn into a whole day's work. .
Howdy Mech, long time no smoke signal🙃 good to hear from ya. That is a fair assumption of the time involvment and I think very possible, I just have to figure out if I want to spend the time to tear it down myself or drop it off at a local shop and bite the bullit🙄.
  • Admin changed the title to fuel tank FTX-4WD KQ 300
    • By noticon75
    • By toe420
    • By cruteg8
      Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport  with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
