By Spritee1
not sure where to look next
By skittle021
Photos:
By DarkRider
By Sofaspud
By p5200
Hello, would this be a good Master Link tool for pressing master link plate back on? I've seen others made of aluminum but thought this one might hold up better. Thanks! 🙂
https://www.amazon.com/BARTOO-Motorcycle-Convenient-pressing-Alignment/dp/B0C4FB1V7D/ref=sr_1_3?crid=1KRW04WLD82EI&dib=eyJ2IjoiMSJ9.4Y2_vOEctIVv0vgmajSYXL844RphCjGBrMsiewv7Z1sVIMYMM5OQNBL0cXeHLmUDsnKMO5JffQPEP8vl4xuxCUczEfKGgw4r-MYmLgCzydGm9sHnK8hX7o1AqXunVpgpR8RrfQ8noUmfLyoxTqUcrl9tj82jDWeB5CL1rifd--ufsiyaWkBl4omd_1qyx7a97BvOTogpK40NTm9BfKjSt2H5mXrjEnhEOcxSYxUHiRx61KbfDBaA8B9CvwQjM3qGIf4Ay1zWxxPURTnX5qjhddcAADez5JNCFVrUYeLE-7M.sFaeyu09Q7O8v9B0NPjaDYDuHqVqE4uyxspDEpxBs6U&dib_tag=se&keywords=chain+press+tool+for+polaris+500+scrambler&qid=1709916341&refinements=p_85%3A2470955011&rnid=2470954011&rps=1&sprefix=chain+press+tool+for+polaris+500+scrambler%2Caps%2C198&sr=8-3
