2006 Kodiak 450 not charging
By LMI
By quadnut20
Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
By tds7
By jannonballs
2001 Yamaha Kodiak. Rebuilt and cleaned carb after sitting for 10 years. Got her runnin but now this clunking noise is happening and sometimes the engine stalls hard like the tranny or clutch abruptly stops the engine. This was not happening 10 years ago. Also the clunk will happen and the rpm's spike. See video. Any ideas before I tear into it?
IMG_4791.mov -
By Mudseeker149
Just bought the atv, sounds like there’s sand in a bearing near the clutch! Any ideas?
