They wouldn't agree with that Gw..  They know different stuff, which I don't, so they think they know more.. haha.
I think it's really because they think I can do anything, and don't really need their help.. Not even when it's lifting something heavy !
Thanks a lot I really appreciate it.Hope things turn out better, never know. Would have like to have finished the job, hate to let anything beat me. Y’all have been great. I’ve learned a lot and it was a great experience because of y’all. Wish we were all closer would have liked to have met you. Take care and be safe and healthy have fun riding and mechanizing. Jeff.
    • By quadnut20
    • By middlebrookgt
    • By sunn
      The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth.   I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale.  Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal.  The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
      The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down.  RNG would not tell me what the spring force was.
      I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM.  Note; idle RPM is approx. 1600.
      I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information.  What gives here?  Anyone with experience to share?
    • By Coyote251
