1987 Yamaha big bear 350 CV shafts
Similar Topics
By Ejwill
Headlights and taillights will not work, the dash light will not come on. Already checked fuses they are all good. Help please. 2006 Honda rancher 350 es.
By Gwbarm
I got my no spark issue sorted out, got it running on the old aftermarket carb, but it didn't want to take throttle even after cleaned it, didnt really want to waste time on it, so I order a new one which is on its way, so not much to post here, but I wanted to start a new thread. I am stating to clean up the plastics thought I might as well do that while they are off, they were a mess tree sap, bird dropping, mold and what ever. Washed them good and got all off so I could see the oxidation , decided to wetsand with 600 grit waterproof sandpaper, and used Armour All instead of water. I figured it could put some of the moisture back in that was lost from sun exposure.
Working fairly well I will keep going finer on the grit and see if it will polish
By QuadMan49
Hello,
Long story short, I accidentally fried my quad's CDI box.
I found several OEM ones for $300 which are out of my price range. Does any one know where to find one for less? Or any way to modify a $20 Chinese CDI to make it work? Thanks.
By blasirl
As stated above I am looking for battery type /brand etc. recommendations. Do ATV batteries come in AGM flavors? My ATV is stock.
By Ejwill
Should the clutch plates be so tight together that they can not be moved side to side? There is no play in them at all, will not move at all.
Similar Tagged Content
Gallery Images
