By RadRob
By BuckBilly
By TravisM
2001 bayou 220 KLF220A
I'm at a loss here. Thanks.
By jwh
I am new to this site. Now down to business, I have been given a Kawasaki 220, tires are trashed and it has been setting for a long time. Do I need a battery in it to find neutral? I know there is a neutral switch and if I shift down(7 times????) then up one using the neutral switch I should be in Neutral. As you see I am in a learning curve here ......coments welcome.
By P_syko
