  • Admin changed the title to 1998 suzuki king quad 300 4x4, where is the rev limiter?
7 hours ago, Mech said:
Oh true..  That's a throttle limiter really but it might be his problem.
I don't have a regular cable. I cut a king quad 300 4x4 in half and put a crossfire buggy in the middle. It runs great but I'm changing gears way to soon because it starts cutting out. That's the problem I'm having. Thanks
Maybe I should have said that in a different way. I have a throttle cable but not the one that came on the atv. Just a cable that came on the buggy. If I can figure out how to send a picture I'll send one of my 4x4 buggy.
Check your charging system, and the fuel supply..
Normally the power just fades away as the revs get high. If it's stuttering like a EFI car hitting the rev limiter then it's quite likely a problem with the charging. The first simple test is just to put a voltage gauge across the battery and see the voltage rises once it's started, and that it doesn't go over about 14.7 after a few minutes and some revving.
    • By BillR94
    • By Bignasty1
      This unit was brought to me this way with a new carburetor on it and read valves it fires up cranks fine but it won't accelerate I push the button in on the override it backfired and blow the head or loose from the spring at the head I'm figuring it's a CDI issue or bad switch or something I just want to bypass it all together and see what happens anybody out there got a clue I'm being told that it will live after I eliminate a wire which wire is what I need to know
    • By Sha35297
      So I rebuilt this engine completely with all factory parts. Transmission was damaged, so customer wanted to replace crank while I had it apart. After putting everything back together, everything worked great. Customer picked up bike and ran it for about two months (he uses it daily for work in crawfish ponds). Brought it back to me because it was overheating and would rev up to about half throttle and the cut out over and over while holding the throttle at anything above half throttle. Radiator was plugged. Everything with ignition tests good. I never loose fire while this is happening. ECM is brand new, fuel pump is new, injector is new, swapped TP Sensor with known good one. Fuel pressure is at 51psi at idle and its hard to tell because of vibration, but seems to drop to about 42psi while its cutting in and out at high rev. Any ideas on what could cause this?
    • By Devon400ex
      Quad seems to be hitting the rev limiter cutting out at a certain rpm almost like a consistent bog at a certain rpm, have replaced the cdi and continued with the same issue even replaced the carb and the same issue continues help
    • By mrfartsalot
      I have a 2001 suzuki quadmaster 500 4x4 that has a rev limiter when it is in any gear other than neutral, i have already fixed a bunch of stuff on it and would love to just bypass it if anyone knows how. Thanks for any help.
      video-1583184277.mp4
