8085.thumb.jpeg.608d041d601700025448d817d1743c69.jpegJust replace the crank trying to figure out exactly how to set up the timing the dots on the crankshaft gear and on the balancer gear are they supposed to match as it rotates
Edited by Tucker17
Add pictures
    • By cruteg8
    • By Ant-Knee
      I am trying to rebuild an engine for a '97 Kawasaki Prairie that I recently picked up. There is one head bold that just won't let go. Nothing I do seems to make a difference. I have been putting penetrating lube on it for two days straight and I am afraid it is going to break on me. What is your best advice for getting the sucker out? I have tried a rechargeable impact, a pneumatic impact and penetrating lube.
    • By cruteg8
    • By sunn
      Any ideas?
    • By Damien911
      Setting the timing on a 2005 Yamaha 250 Bruin
