When turning the ignition switch to start the machine, the console lights up but does not engage the engine (will not crank over).  I replaced the ignition switch, but have same issue.
Thanks for any suggestions,
Dave
If pressing the start button does nothing at all, no dulling of the dash lights, no clicking noises, then you need to get a wiring diagram and check the power from the key switch is getting to the kill/start switch, and through it and to the start solenoid.
It sounds stupid, but make sure the kill switch is in the RUN position before you spend money on anything. If it is, then just try to jump the started solenoid with a wrench to see if the starter turns. You’ll know if power is getting to the starter if the wrench sparks and flash welds.
If the starter turns the engine over, then you have it narrowed down to either the kill switch or the solenoid. Both much cheaper than a starter.
    • By realpilot
    • By OldATVowner
    • By Dsluder
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
