I have a 2015 sportsman 570 in the shop currently with a cracked oil pan. It is a rental unit, (not my own rental company but a customer's) and the renter that was riding it apparently hit a large rock and dented the bottom of the skid plate into the oil pan and has cracked it where the drain bolt is. (And before any-one tells me to just JB weld it, I am not going to do that for obvious reasons relating to it failing down the trail. :) ) It is a quite large chunk that is broken and oil drains out about as fast as you can pour it in. I currently have the customer quoted for removing the engine and replacing the oil pan. Is this the best option? Or should I be looking into cutting the skid plate out, replacing the oil pan, and welding the skid plate back into place? Has anyone done that before?
Thanks!
I totally agree, oil pan needs to be replaced. I know JB weld is a standard cheap fix but i have not had good luck with it. If it was mine i would pull the engine and replace the oil pan, but since it is a rental unit i might be tempted to go with the easier option.
Well, I should also say that I would consider myself a very novice welder. That and worries about structural integrity of the chassis are my only concerns about doing it that way. It would definitely cut a lot of time out...
I would agree I’m no pro welder myself and structural integrity would also be my concern plus that takes time also. That’s why I said if was mine I would pull the engine, but you also want it safe for your customers , so I would just take the time and pull the engine,it shouldn’t be too bad .
Taking risks to save a customer money is something that needs to be discussed with the customer, and put in writing. I'm a mech, that can weld, but I'd explain the options and opt for pulling the engine.. If they want to save some labour by cutting the bike then it's their risk.
Cool, thanks for the input. I already discussed it with the customer and recommended to R&R the engine. Anyone have an idea of how many hrs that should take? My guess was 4-6 hrs but I might be way off.
    • By flyinbrian365
      What's Covered:
    • By quadnut20
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
