As it should be easy to see I am not a four wheeler mechanic so I apologize for asking for help, I replaced my OEM carburetor with a aftermarket carburetor and with y’all’s help adjusted the air/ fuel and it ran great until this evening and I noticed a smell of fuel I inspected carburetor area and found a steady flow at the vent line on the bottom of the carburetor so my question is is the float the only thing that will cause this problem? Before I installed the carburetor I checked the jets for tightness and they all seemed fine?
The float could be stuck partly open or  misadjusted. about the only thing I can think of otherwise is if there is a drain valve on the floatbowl bottom it could be stuck open  by a bit of debris if you   pushed the button  to  let a little  fuel/  water out.
It sounds like the float needle has got some dirt or fluff under it. The float needle's seat has an O ring to seal it to the carb body and those can leak too but it shouldn't be the case with a new carb that was ok to start with. Check the drain screw is done up first though if it has one, or check the drain valve if it has one as Dave is suggesting. I'm in New Zealand and I've never seen a drain button. I'd also turn the tap off and run the bowl empty, then turn the tap on and start tapping the carb body fairly hard around where the float needle is with a screwdriver handle.. It may just flush the dirt or wriggle the needle into a better position and it might come right. It works sometimes !
Sounds though like you might need to clean the fuel tank or tap filters or fit an after-market fuel filter.
  • 7 months later...
      Hello there
    • By Callaway
    • By Gkb
      Need ideas for all aftermarket accessories for my new atv
    • By 97kingquad
    • By TravisCr
      I don't know if I shouldn't have posted but I this is my second post on this (other was in regionals Forum)  The family has a 2-up 2004 Artic Cat and a 2003 Polaris Sportman and we are looking for fun/easy rides in the Colville, WA area- 70 Miles North of Spokane WA, we have a small trailer we can haul these with but need to find some good areas for beginner.
      Thanks in advance for any suggestions.
