Does anyone own a Massimo MSA450 ATV Quicksand oe see these? It looks like Tractor Supply sells them for $6K. It looks pretty solid, has independent rear suspension.
Here's the listing on tractor supply:
Massimo website says
Massimo MSA 450 - our powerful, single-cylinder, 4-stroke ATV. With 25 horsepower and a top speed of 42mph, this middle-weight ATV offers Hi and Low forward gears, neutral, and reverse, along with selectable 4WD. Boasting 11 inches of ground clearance and 25-inch tires, the MSA 450 tackles any challenge while carrying a load of up to 350lbs and towing up to 800lbs.
  • 352cc 25 HP EFI 4 stroke engine
  • On demand 4WD with 25 in. AT tires
  • Front & Rear Rack
  • Hand Guards
  • Front Bumper
Try buying some parts.. Unlikely parts, parts that never break on a jap but do on these, like a gearbox shaft or a back axle, wheel hub.. something like that.
Edited by Mech
Good point. They beat the mainstream manufacturers sometimes by $2-3K
The website says they have been in business since 2009 didnt say anything about where the engines come from. I would be careful buying it without knowing more about the company and if parts are readily available.
Seriously Grizzly.. Some of these new brands do break gearbox shafts, kickshafts, axles, cranks, wheel hubs, diffs, stuff you'd never imagine would break, and the parts are hard to get in a lot of them.
    • By noticon75
    • By toe420
    • By Callaway
