Hello, what is the best method for installing bearings into their race? I've set one in place and tapped it down until it was metal on metal. Is that sufficient? Surely it's not supposed to go into the race until flush? Also. does the coil spring on the seal go into carrier bearing housing not facing out? Thanks! 🙂 Seal goes in until flush correct?
Edited by p5200
Yeah the bearings will go in till they come up against a lip. The seal does have the side with the spring facing inwards.
Not sure how far in the seal go but you should be able to see where they ran on the old shaft. If the axle shaft has damage where the seal runs, it's ok to position the seal slightly further in or out so the new one runs on a good surface.
Edited by Mech
The method I use it a hammer and then a punch. Hold the bearing down on the housing and then tap lightly all around the outer bearing race with a hammer. For those axle bearings you don't tap on the inner race, because it will cause the balls to damage the races. If it was a bearing on a shaft though, they you would use a punch and tap on the inner race.
I usually use a small hammer to get the races started in and once in the hole get a piece of iron pipe or socket the right diameter to push it to the correct position, you can hear when it gets there the sound will be different. I have used a punch but feel it goes in evenly with something of the right diameter.
Yeah a socket's good because you can tap it in the center, but if you have to tap around the sides then it's much of a muchness.
One of the old bearing cones would probably be ok to use in this case, as long as it doesn't get stuck in the housing..  haha. Tap it in the same way it was originally and you'll be able to use a punch again to get it back out.
If you are using a punch to tap the new cup in, use a small diameter one that doesn't touch the inside where the rollers go, just use it out on the outside edge of the cup.
Well, it's all back together. My only concern is, I hope I got the clip on the chain link fully. With my failing eyesight I don't have a lot of faith in things such as that. I test drove it and everything seemed fine I just hope the chain stays together. I want to thank everyone for their experienced support through this job! 👍
    • By RadRob
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
      This past weekend the 2025 ATV Motocross National Championship Series (ATVMX), an AMA National Championship, held its third round of AMA Pro ATV racing, and its first amateur round of racing at Echeconnee MX in Lizella, Georgia. View the full article
