  • Ajmboy changed the title to 1996 Yamaha Timberwolf 4x4 Struts and Shocks
I’ve sort of done that for the struts by looking them up on parts diagrams not the actual stamped part number on the strut.  All I can find are used on eBay not sure they’d be much better than mine.  I will do that. Thanks for the advice
Alright guys. I need some help with this rear shock. The one I thought would work is two inches too long.  I’ve removed the old shock. It’s 360 mm eye to eye or 14-1/8”, set on the highest setting. The eyelets are 12mm or .459” the spring which may nor be a big deal is .366” sorry didn’t get a metric measurement. And the body of the shock is 1.5” and some change. The width of the top eyelet is 40mm and the bottom is 45 mm. The biggest problem I’m having is finding that length matched with a 12mm eyelet.  I could get  one with 10 mm eyelets but then I’d have slop in the anchor points in the quad using 10mm bolts.
Update on the front struts from Canada. They work great but are 7/8” longer than what was on there. The tires lean out slightly at the top but it’s fine. Had to bend the bottom edge for more clearance from the cv axle.
    • By noticon75
    • By Elk
      2002 Polaris Magnum 325
    • By Shorty51
    • By toe420
