    • By anthonyd256
    • By dvs1961
    • By Whiterabbit
      Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!!  I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
    • By autocustomizer76
      Hey all got a Kawasaki 300 that's seen better days I'm looking to get running.  But first, I'm working on a Honda 350 ES and mainly needing where are you all finding quality parts at good prices.  Atvs are really hot items around here right now and most of the folks wanting and needing them are not familiar with working on them.  I'm looking to find a good resource for information and if it works out well pass this group along to the folks I help to get them in the know how to get the most out of their machines.  Thanks in advance.
