Do the small 50cc's have a way to set the speed. Im wanting to get one for my kid and i need to set it to go slow. I know the chinese knock off fourwheelers do but i dont really want one of those
  • Ajmboy changed the title to Do the small 50cc ATVs have a way to set the speed?
Most of the smaller ATVs I believe have throttle limiters and not speed adjusters exactly, but it will allow you to keep them below a certain speed if they can't give it more gas.
* Topic moved to General ATV Discussion Forum and adjusted topic title
30 minutes ago, Weazel said:
Some do, depends on brand and model.  Also could slack out the throttle cable so there is less travel?
never thought of running a cable thats to long. thats a much easier idea then wedging the slide.
On the old Suzuki 2-stroke 50cc, they used a restrictor plate/washer between the exhaust pipe and head to slow it down.
On the 80, they put a spacer on top of the carb slide so it would only open half way.
I was thinking you could just back out the adjustment.  I'm not sure how it attaches at the carb but there should be something on the handle bars.
  • 2 years later...
I had the Polaris Outlaw 50 which is one of the smallest quads available. The CVT transmission allowed for very smooth starts. The front tires are set up with a lot of camber to prevent the quad from rolling over. The thumb throttle had a limiter bolt that you could turn in or out to limit the travel of the thumb throttle. While this limited the amount of power the engine produced it was still possible for the quad to achieve fairly quick speeds on a straight downhill run. It is a balancing act of allowing enough throttle travel for the torque to accelerate on an incline but not have to high of a top speed.
The youth Polaris Ranger 150 has ride command which does limit the speed while not detracting from the torque. You download an app on your cellphone then select the speed exact speed and push the settings to the side by side.
  • 3 months later...
Throttle Limiter screw!
I did not know that.
  • 2 years later...
    • By BillR94
      Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
    • By shorty
    • By johndeerefarm
      Is there any way to mod an Outlaw 50 to increase the speed? The size is perfect just would like a little more top end speed. Thanks
    • By p5200
      I added more fresh gas it sat one day now, it's acting up again. Before cleaning out carburetor it wouldn't idle good and had gas leaks from carburetor. Now it idles pretty good but, if I increase throttle speed at a certain amount it starts missing bad. I'm going to try and post a short video. Just about ready to give up on this thing.😒  you can see reflection perking in video.
      20240217_114429.mp4
