transmission or belt ?
Similar Topics
By Fish0rDie
Was told there was some good information on this forum, so I'm here engaging in some good ole conversation haha. Bought a buggy aka shitcart for 100 dollars. Thing was a woods toy for the past owner. Used and abused until she went boom and was left in a field to die. All things considered that may be an exageration, but the top end of the warrior 350 that was on board was absolutely mangled. Piston and head assembly were totaled. Have a new jug, piston, and head assembly, but struggling to get the crankcase back together without the transmission binding. Can share pics that are on my phone if anyone is interested in seeing this shitty story unfold.
By hporter1208
Okay, so I have a 2002 Rubicon 500…bought it last year and it sat for several months until I put a new rear axle in, FINALLY got that done and was super excited to finally have my wheeler going, just to notice a strong gas odor. Popped the seat off and sure enough, pouring gas from the carb overflow. Fast forward a few more weeks and get the new carb and get it in, no leak! Yay. Except now I have no spark. 😒 I’ve tried another plug and checked and am getting no power to the coil pack. I’ve read and read and mostly what I’ve found is ECU, which is fine…but I like to exhaust all avenues before buying the more expensive parts just because I don’t wanna spend the money and it have ended up being something simple that I overlooked because I was trying to rush. 😂 I don’t know if it’s relevant, but I read on another post that someone had similar issues with theirs and it was the sensor on the side of the carb, just a thought since this literally happened after I put the new carb on. It also displays “- -“ on the display screen where it should show the gear position.
By Powersrepair
I have a Suzuki lt185 and she is sounding like a cammed diesel after installing a new carb. Would running it like this be bad I can definitely adjust if needed but it if won’t cause damage why change it.
IMG_5131.MOV
By Shadow1
Now i have that korean atv he making a noisy sound on the rotor side so i checked it and i have the starter driven gear moving in its place there is like a 10 mm space that the gear can go back and forward and a little space between the gear and the crank i think theres a beering missing!!
By BuddyLee
Just started to bog in gear. Chineses carb. Taken apart and cleaned. Starts good, runs good, throttles good sitting there but as soon as try to go it will bog. Plug is black so I cleaned and adjusted needle downwards. Kinda lost at this point…ideas? Thanks in advance.
Similar Tagged Content
- 7 replies
- 2,646 views
- 3 replies
- 2,282 views
- 1 reply
- 3,305 views
- 7 replies
- 2,540 views
- 0 replies
- 3,127 views
Gallery Images
