Hi Everyone,
I recently purchased a 2005 50cc Polaris Predator for my granddaughter.
The wiring is a mess. most of it appears to be jumpered out (twisted together).
I installed a new carburetor. The gas tank was cracked so I found another one on ebay and got that installed. There is no air filter box. I ordered another one but, it has not arrived yet.
I did get it cranked with the kick start. But, it idles too fast and when you give it any throttle the motor dies off. The more throttle you give it the faster it dies off. It is very hard to start when it has not been running for a while. However, once it has warmed up, it starts on the first kick every time after that.
I am looking for a little assistance in getting it running better and also a wiring diagram and service manual if possible.
Thanks in advance....
Edited by exalrod
To really tune the new carb you need to get the air filter installed. If its an aftermarket carb you may need to adjust the cable length for the throttle, they do not always fit exact, may be why its idling too fast. Try adjusting the mixture screw to see if it will run better.
@Gwbarm
Thank you for the reply. I tried adjusting the mixture screw but, it does not seem to do much to help, I may need some advice on how to adjust the cable length for the throttle. For now I will wait until I get my air filter as you instructed.
You just want to make sure the throttle plate on the carb is closed all the way when the throttle is not being pushed, if needs adjustment, take the cable out and there are 2 nuts that you can move to get the correct tension on the cable.
You can see the 2 nuts for adjusting in this phot, this is on a suzuki but it should be similar.
There will likely be an adjustment for the cable on the throttle hand-piece as well. If the cable outer can be pulled out of the throttle hand-piece by a couple of mm or more it should be enough, then try adjusting the idle speed screw to slow the idle, then adjust the mixture screw to best slow idle then slow it with the speed screw and recheck the mixture screw. Keep doing that slowing it down to it's best slow steady best mixture position, then wind the speed screw in a little to give the proper idle speed.
Oh, and when checking the free play in the cable, swing the steering hard left and right and check the free play there and compare it with the center position.. The free play can alter when the bars are moved.
  • Solution
Yes it is different, i should have looked it up , i thought they all had vacum slides now. Your cable adjusting screw is the big silver piece closesst to the carb, just make sure the slide is all the way down with no pressure on the throttle.
9 hours ago, Quad4 said:
Here yo ugo
this is a great source for manual for everything  manualslib.com
Hopes this helps
Link removed. There are nothing but links at that url. The predator manual is in our downloads section:
    • By LashinWheeler
      Any help would be great,
      Thanks!
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
