When the machine sits a few days I have a week/dead battery.
What I have found,
1. There is a group of four smaller gauge wires connected to the positive side of the battery. One of these is a blue wire, with the key off there is a .5amp draw on this wire.
2. When I pull the EFI relay it is warm and the .5amp draw stops.
3. I can reinstall the relay and the draw does not return until the key is turned back on.
4. Swapping the relay with another does not change the condition.
5. Turning the engine kill switch to stop does not kill the draw.
I am assuming that when the key is turned off the EFI relay should relax, but is not.
Does/should the key to off remove the control power for the relay, and therefor relax, or does the ECM control this relay?
Thanks for any help.
Chad
You have done some great investigative work. I would trace the blue wire to the key switch and make sure everything is good there, with the relay unplugged check to see if the wire still has voltage on it. I would have guessed the relay, but you checked that. My thought is the relay might be sticking and once you unplug it and plug it backin there may not be enough power to work the relay until you turn the switch to on.
I can't find a complete wiring diagram. It seems strange they would have so many small wires connected to the battery though. I think the winches connect straight to the battery and that has a blue wire, so perhaps look at/disconnect that first.
It sounds like what's happening, is that there's a short somewhere(perhaps in an electronic component), that's feeding power back into the main ignition lines when the key is turned on,(turning the key on makes some relay or electronic unit switch some circuit on), then turning the key off disconnects the power from the key switch but the short/.bad relay is keeping the main power live.. I'm not familiar with Polaris so wouldn't know where or what that would be.
I think I'd disconnect the winch, pull all the fuses and all the relays and try reinstalling them one at a time.
If you have a complete wiring diagram Chad, post it up and I'll take a look. I'll keep searching for a full diagram.
Oh, afterthought..  A bad earth on some component could cause 12v that's meant to be shorted to earth inside the component, to reroute back through some other key switched wire coming out of that component.
I'd also disconnect the voltage regulator when I was disconnecting all the fuses and relays.
I would definately unhook the wench wires if possible, until you get this sorted out, but if its a factory installed unit it mat be incorporated into the rest of the harness.
Update: I found a Polaris reference that said once the power is turned off to wait at least 10 minutes before checking for parasitic drain. I rechecked after 10 min and the draw was still there, however, after 15 it was gone. I have a second sportsman that is two years new and it acts similar. Decided to just change the relay since it was hot, unfortunately, this did not help. I had a dead battery again this morning.
OK, so it was recommended to have the ECU flashed or replaced. Am I able to flash it myself or does it have to go to the dealer? Is there a procedure for doing this myself?
Next step I guess is to check grounds. It is just weird, I had an amp meter on the battery and once 15 min was up there was no draw. What ever caused it started back up, or I need a new amp meter for my Fluke (wounded how the wife will take that).
Open to your ideas…
Thank You
Chad
A relay shouldn't, and doesn't, usually get hot, not even under a heavy load and being switched on continuously..  The contacts should be able to carry a big load without getting hot, and the trigger winding should be able to carry it's tiny current indefinitely without producing any significant heat let alone being hot.
I'd disconnect the load wire from the relay and see if it still ran hot, then I'd disconnect the trigger wire and see if it still got hot..
He did ..  So which part of the circuits is causing the heat, the windings or the contacts, or perhaps.. a diode in, or a diode missing/blown in the relay...
I've since found the wiring diagram and if there is only one blue wire, it should turn red after a splice/connector which connects it to the main loom, and then, as a red wire, go to a splice which branches red four ways to the fuse panel. The blue wire, or it's connection where it joins the loom is a fuseable link. The manual will tell if it's the wire or the connection.
If there is a second blue wire from the battery it's the same fusable link setup(but a seperate one), and it then goes to the speed sensor..
    • By Atomusthenes
    • By killerklown
      What is the blue wire at taillight?
      I went to NYC over the weekend to see the tree at Rockefeller with tha family, and on the way down from about 50 miles north could not help but keep looking in the sky while driving at diffent lights. Planes, small planes, choppers? Some of them looked like slow moving drones but not really sure. If you are in the tri-state area, you can't help but wonder what's going on... thoughts?
    • By Brad1968
      I purchased a '87 Moto 225. It didn't run. After getting it running, I was surprised it smoked like a smoke stack because it was rather quick. I'm guessing it's the head gasket.
      Has anyone had a smoking problem?
      My 2004 Yamaha Grizzly 660 is still going strong but the battery has not been holding a charge. I replaced it a few years back and have been jumping it lately but after sitting for a few days, it drains out. I recently purchased two car batteries from Weize directly because it was a good price for an AGM. I looked on weize for a YTX20HL-BS and its an AGM at $59.99. I believe they have a promo code you can find. Found it cheaper on Amazon and intalled it yesterday.
      I ended up buying the same one on Amazon which is $49.99 with a $20% coupon bringing it down to $39.99, which is a pretty good price for an ATV AGM battery.
      Just a heads up if anyone needs a new ATV/UTV battery going into winter.
      YTX20HL-BS fits a a good amount of models.
      Arctic Cat:
      Arctic Cat Alterra Arctic Cat ATV 450 Arctic Cat Alterra TRV Arctic Cat Alterra CORE Arctic Cat Alterra XC450 BRP (CAN-AM):
      BRP (CAN-AM) Outlander BRP (CAN-AM) Outlander 660 EFI BRP (CAN-AM) Renegade CF Moto:
      CF Moto Cforce 500 Honda:
      Honda TRX680FA Four Trax Rincon Kymco:
      Kymco Maxxer 450 Kymco MXU 450 Kymco MXU 500 Kymco MXU 700 Polaris:
      Polaris Sportsman Polaris Sportsman Touring Polaris Sportsman XP Polaris Sportsman X2 Yamaha:
      Yamaha Kodiak 700 Yamaha Kodiak 700 EPS Yamaha YFM40FB Big Bear Yamaha YFM40FW Kodiak/Automatic Yamaha YFM40FWN Big Bear Yamaha YFM450FA Yamaha YFM45FA Kodiak Yamaha YFM45FG Grizzly Yamaha YFM45FX Wolverine Yamaha YFM45KD KP Kodiak Yamaha YFM600FW FH Grizzly Yamaha YFM660FP FR FH FL Grizzly Yamaha YFM66FA FG Grizzly Yamaha YFM700DE DH PE PFPH PS Grizzly Yamaha YFM700GD GP Grizzly Yamaha YFM7FG Grizzly Yamaha YFV600FW Grizzly Yamaha YMF5FG Yamaha YFM550PE DE DH Grizzly UTVs:
      Arctic Cat Prowler 500 BRP (CAN-AM) Maverick BRP (CAN-AM) Traxter DPS BRP (CAN-AM) Traxter Base BRP (CAN-AM) Traxter STD BRP (CAN-AM) Traxter BRP (CAN-AM) Defender Kawasaki KAF620 Mule 3000 Kawasaki KAF620 Mule 3010 Kawasaki KAF620 Mule 3020 Kawasaki KAF620 Mule 3010 4x4 Kawasaki KAF620 Mule 4010 4x4 (CN) Kawasaki Teryx All Models (CN) Kymco UXV450 Kymco UXV500 Kymco UXV700 Polaris RZR Polaris RZR 4 Polaris RZR S 800 Suzuki 2005 QUV620F
