Hoping against hope that you will tell me that my '86 225 Moto4 is not as bad as I think
Thanks for any thoughts.
It's sometimes possible to remove the tensioner, drop the cam sprocket off the cam, let the chain off so there's more slack, then try to get the chain to go back on the bottom sprocket by manipulating the chain, possibly with a length of stiff wire down the hole levering the chain over. Then put the chain on the top sprocket, lift it onto the cam shaft but don't put the bolts in, check and redo the cam timing being careful not to bend any valves, then assemble it back up. If you can't get the chain on the bottom sprocket then yeah, you take the side case off again.
Stateing the obvious perhaps, but, you have to check the cam timing with the slack taken out of the chain and all on the tensioner side.
I'm not sure how much travel the tensioner should have, but it needs to be enough to take the slack out of the chain. It would be a good idea to figure out why the chain slipped. The tensioner has a ratchet mechanism, visually check the teeth  and pawl of that, and test it lightly, with big pliers perhaps, but only gently.. The other thing that happens is that people don't get the two slippers sitting in the correct places at the bottom, or even up the top on some models. If/when everything looks and tests ok then put the tensioner back in and turn it over..
Pulled the cover,stator and fly wheel and found the chain off the sproket. Replaced, timed turned by hand. doesn't seem to have much compression. spun it with the starter and did not start. Checked the tappet gap and found them to be off from what I had set originally. Haven't been back at it but seems like I might run out of threads when I get back to adjusting the intake valve. Both vales seemed to be operating ok by looking thru spark plug hole. Hope to get back at it in a few days.
You've got a bent valve or two preventing the valve from closing right down onto it's seat, and that's why the valve clearances have opened up and why there's no compression.
Head off again I'm afraid.
I'm suspecting now that a valve is bent. If when I originally turned the engine over and it fired for about 4-6 times I heard something. If the chain was riding on one side of the chain and when it fell off the sproket could the valve have hit the piston and got bent?
GM, didn't see your last post about the bent valve until after I asked about it.
The original cylinder gasket had the open spaces on three of the holes and included an o-ring. There is no seat for the o-ring on the cylinder I bought and the gasket I bought does not have the open spaces on the gasket. Is this ok?
    • By Randel1
    • By motox88
    • By Does_This_Look_Bent?
      Hey everyone, I just replaced the carp on my 98 Kodiak 400 with PN#4SH-14101-00-00. It starts and idles perfect, but once it’s good and warmed up, it bogs out at 3/4 throttle or more… it sounds like it’s bouncing off a rev limiter haha… I tried the air fuel screw, all the way in and out 2-1/2, and it made it a touch better… tried 2 turns and no different. Am I missing something?
    • By Malta54
      I own a 2007 Polaris Sportsman EFI X2 model and have for the past months been experiencing loads of issues. Basically the Sportsman will only start if the throttle lever is pushed and will not remain on idle. This situation has persisted for months now and I have replaced the following parts:
      Sparking Plug
      Fuel Injector
      Fuel Pump
      Fuel Filter
      Fuel Valve
      Fuel lines
      Power Control Module
      The last part replaced was the Power Control Module and the Sportsman was tested and worked fine on a couple of occasions which were days apart so much so that some weeks later I took the Sportsman for an extensive ride and it worked perfectly. This was three weeks ago and today I tried to start the ATV it worked fine a few minutes and decided to switch it off so that I could continue with some prep work. A few minutes later tried to start it up again but noticed that it would only start if the throttle lever was pushed and once I removed my finger from the throttle lever the engine would not stay in idle and would simply shut down. Several attempts were made to start this and also tried to re-adjust the setting by turning the built in wheel like mechanism in the throttle cable but it was to no avail.
      The above have been repeating itself on an off basis. Each time a part is replaced the ATV would work and then all of a sudden will not keep its idle. At this stage I cannot think of any other solution other than possibly some sensors which might have an intermitting fault but I cannot really say.
      Would greatly appreciate any assistance.
      Thanks in advance.
