Hi!
I would like to know if anyone likes antique snowmobiles and racing, for my part I own a yamaha srx1980 with an ex433 engine, I am preparing a GPX433 engine for this year, picture is coming 😎
Create an account
Register a new account
Sign in
Sign In Now
    • By bigd764
    • By Feehan
      I bought a bear tracker off a friend who said it last ran a year and a half ago. He was going to use it, went to use it and it wouldn't start. He took it to the dealership, and they told him it needed $1200 worth of work one of the things being it needed a new stator.
      I bought an aftermarket stator and in put it in, rebuilt the carb and changed the oil filter, installed a new petcock and gave it a new battery (voltage is 12.8) and oil.
      I turn the ignition on and I see a green N light on. I turn the ignition switch to run and push start and I hear the click of the solenoid and the starter cranks but the 4-wheeler never turns over.
      I have pulled the spark plug and have ground it to the motor housing. I try push run, but I do not see any spark from the spark plug, not even once.
      What should I look to next? I can't for the life of me find a CDI box on my model. If I do it must look and be at a different location of where I am looking, nor can I find a CDI at any parts store which leads me to believe my model doesn't have one.
      Please excuse the ignorance as I am new to this, but I do have a rectifier and ECU that I do so.
      Any help would be greatly appreciated, I just don't know what readings I should be getting from the pickup coil, stator, ignition coil, etc.
      Thanks in advance for any assistance you may be able to give!
    • By DaleJAM
    • By Need-help-with-quads
      So my moto 4 is smoking white smoke and when I go to first gear and get about half throttle there’s no power and it sounds like it’s bogging
    • By disturbedmike244
      I have a 99 kodiak 400 4x4 that blows a fuse under the back left fender as soon as you attempt to put a new one in even with the key turned off. I'm having a hard time finding any wiring diagrams that show what this is for. And I'm trying not to have to tear into the wire harness. Any help would be appreciated.
