If it's got a carb, the carb's float level needle/jet is probably leaking allowing the fuel level to get too high so it overflows the carb and goes into the cylinder, down past the rings and into the sump.
It is fairly common though for needle to leak very slightly and it not to be a problem during a days riding, but if you leave the tap on over night they can try to fill the sump.. So check the tap turns off.
Another thing that can cause it is if they have a vacuum operated fuel pump that plays up..
