Secondary pulley rollers
By Gwbarm
I got my no spark issue sorted out, got it running on the old aftermarket carb, but it didn't want to take throttle even after cleaned it, didnt really want to waste time on it, so I order a new one which is on its way, so not much to post here, but I wanted to start a new thread. I am stating to clean up the plastics thought I might as well do that while they are off, they were a mess tree sap, bird dropping, mold and what ever. Washed them good and got all off so I could see the oxidation , decided to wetsand with 600 grit waterproof sandpaper, and used Armour All instead of water. I figured it could put some of the moisture back in that was lost from sun exposure.
Working fairly well I will keep going finer on the grit and see if it will polish
By borgunit
My recently acquired Honda Rancher has a hazy instrument panel. Is the best way to fix this the same method as fixing auto headlights? Thanks
By blasirl
I have searched youtube and also looked at the manual. It looks like I just pull the top center attached pin and lift and rotate clockwise. Does that about cover it? I just do not want to break anything.
