You should check the resistance value of the stator windings and the trigger/pulse windings; the windings may be ok. A flake of metal, or a finger of rust powder, that bridges the air gap between the flywheel magnets and the winding core, can stop them working.
You should check the kill switch too for dirty contacts or rusted spring, and the main switch if it sits out-side getting wet can likely get water into it causing the same problems. The handlebar switches though on most bikes are fairly prone to dirt and water.
There's a service manual in here in the manuals section. That will have the4 diagnosis process and all the readings for checking the cdi. They will tell you to check the resistance readings, but they probably wont tell you to check there is actually power coming out of the windings. There are several things that can prevent the windings working properly even though they have continuity and the right resistance. The wires to the cdi can have bad connections too so I'd suggest you check the windings resistance and output at the cdi plug, or, at the plug and down at the engine plug so you can compare the two readings. To check the main charge and cdi charge windings you can use  a digital meter but to check for output from the trigger/pulse winding you should buy an old fashioned analog/needle gauge. The needle on the analog gauge will flicker and you will see it has some output and know the flywheel is turning, the winding is bolted on in the right place, there is no build up of metal dust shorting the magnetic field etc.. Most digital gauges don't detect the brief single pulse on the volt range.
Doh.. Just reread and noticed you do have the manual and have done the process..  still check for out put though, and do the tests up at the cdi plug.. Wires get dirty connections in plugs or where the terminals crimp onto the wire.
Also..  I thought that connecting the rear brake lights made the light come on. It also doesn't make sense that connecting the wires would effect the spark, not if it is the brake light. Some models though do have a feature to stop you trying to drive with the handbrake on, and the left handlebar brake lever switch if it's playing up(or if you have the handbrake on), will rev limit the bike at barely above clutch lockup speed.
I donated that manual in downloads but I've never read it. haha..  I better go read it..
OK I made some progress.  I purchased a pit bike CDI and put it in the circuit.  This is something that I would not want to run with but for the price it was OK for checking some things.  When I put that in I now have spark and it will attempt to start.  I do know that I need to go through the carburetor still but this is a start.
This is what I know now.
With this CDI I am getting spark and it is attempting to fire.  That tells me that the stator inputs are good.  So this brings me back to either bad input signals to the CDI or a bad CDI.  Unfortunately, the CDI for this unit is not available.
On my unit as well as the schematics for both the 1988 and 1990 the brake switch input just goes to the CDI and not the brake light.  I wish that I had the schematics for the 1989 but have been unable to find them.  I do not have access to the downloads yet so am unable to see if what you uploaded is for a 1989.  I assumed that it was a interlock to prevent it from starting without the brake on but a rev limit also makes sense.
The bike has been in a garage for the last 7 years or so and for most of its life was stored inside.  This bike was my fathers until he passed several years ago and he used it to get around the property as well as plowing snow in the winter.
I did check the outputs from the stator and had 92VAC on the source coil.  The trigger coil had just mV and I was using a Fluke digital meter.  It has a bar graph on the bottom of the display but I will have to remember where I put my analog meter but haven't used it for awhile.
Ok. It sounds like you know your way around electricals..
The manual does 87-88, 89-90. It has the diagrams. If it's not in the supplement for your year, then the details/specs/diagram for your model/year are the same as the first model covered.
You could try swapping the trigger wires about. Some cdi fire at a certain rising voltage of the trigger's output, and later models fire as the trigger winding's voltage peaks.. at the top of it's voltage wave. Those later ones need to be the right way about too. If that doesn't work you could try swapping the capacitor charging wires about too. Some cdi seem to need a certain number of AC pulses before they will start, or it might be they need to finish charging on a positive wave, I'm not sure why, but it's so. And, you need to try all four possible combinations to be sure you have both windings right for that cdi unit.. And.. to make it more interesting for you, you have extra wires to try I suspect..
Also.. not sure if it applies here but my sons used to be forever swapping cdi and stators etc trying to keep their fleet of two wheelers going, and they found that the manufacturers swapped the position of the keyway in the flywheel sometimes, and, even if the key was right, they sometimes swap the magnetic polarity of the magnets. All that aside, they did mostly get a combination that would work eventually.
Thanks for the schematics.  They are the same as the ones in the manual that I have.  It is weird that my 1989 more closely relates to the 1990 model.  They do not have upgraded schematic in the supplement that I have for the W or 89 model and as you mentioned I expected it would be represented in the prior year instead of the later year.  I think that the next step for me is to open the stator housing and look in there.  I had thought about some rust as you mentioned but as it was in oil I was kind of ruling that out.  I was getting ready to clean the carb so will finish that before going further.
Interesting.  I have the original CDI unit along with the original stator.  This is something that I will keep in mind if I have to start swapping in parts.  I did buy a CDI from amazon for the 87-88 and that did not work and if I put that back in will try swapping wires around.  Also, there are 2 different pickup coils on it although they have changed the wiring on the stator so that the second one is not hooked up.  On the 87-88 schematics there are 4 wires going to the stator connector and on the 89 there is only 3.  On the 90 stator they deleted the second pickup coil and placed the source wiring in the 4 pin connector instead of on bullet connectors.
OK I am beginning to understand all the imputs and outputs of the CDI on my ATV.
On the ATV side of the ATV you have 2 3 pin connectors and one bullet connector.
On my 1989 ATV and on the schematic for 1990 and later ones
Bullet connector is the input to the coil.
5              This is ground
6              Kill switch.  This is ground provide by either the "main switch in off postion" or the "handle bar rear brake switch in the on position".
7              No wire on the 1989 and later ones.
8              This is a output to provide a ground to the Starting circuit cut-off relay.  Not sure of its function but assume that when the ATV is running that it turns off the relay disabling the starter.
9              Front stop switch for the rear brakes.
10           Neutral switch.  Same lead that powers the neutral light.
On the Stator side of the CDI.
On my 1989
2 bullet connectors which are the source coil.
1              Pickup coil #1
2              Pickup coil #2 ?
3              Pickup coil #1
4              No wire
On the schematic for the 1987 and 1988 there are 2 pairs of contacts.  One pair going to ground and the other going to power.  It shows both being enabled in the on position.
On the schematic for the 1990 and later same 2 pairs of contacts.  One pair going to ground and the other going to power.  It shows the ground pair being enabled in the off position and the power being enabled in the on position.
On my 1989 it works the same as the 1990 ones.  In the online parts places and on Amazon it shows that there is only one part # for all the years so I am assuming that the 1988 and older schematics are wrong.
Edited by RGS
That cdi unit then has a integrated circuit that takes care of the spark and timing, and the IC also controls the start isolate relay. It monitors the brake lever and the neutral and doesn't let the relay work if it's not satisfied. I'd suspect that one of those two earth wires might be to handle the power for the relay.. Just something they would do on cars;.
These yamahas are absolute mongols for changing a lot and in many different ways. The start isolation can work in two different ways in yamaha cdi. In some the voltage from the start button being pushed gets fed into the cdi, and in others the power goes through the cdi and then to the start button and they detect the voltage drop. The reason they want to know when the starter's being used is probably so it can retard the timing for an easier start. The way they detect start in them puts them into two wide categories where there are several options.. It5 always pays to check which way they detect the start signal. Also, the colours of the wires, and the colours and shapes of the plugs have to be completely right before you can be sure the match is correct.. That applies to the wiring diagrams and original parts..
You really need the good manual. In manuals they describe some of those stator cdi charge windings as anti-kickback or some such, and in some stators all the cdi charge and battery charge windings look identical, some have a slight difference in windings and some have one huge winding and the rest small.. Keep posting till you can get the manual
In the pdf manual index they say they have a model  87-90 YFM350ER, and it has a wiring diagram,the next model covered is 88-90 and it has a wiring diagram, the next model is the 89-90 model and it doesn't have a wiring diagram, then there's the 90 model and it does have a wiring diagram. They have slight variations in bikes in different markets, and they release/use different spec bikes at different times too.. If you find a service manual that seems perfect in some regards, it's often wrong in some other matter. All the makes are like it, but yamaha ignition systems seem/are particularly prone to differences.
The 89-90 model that doesn't have a wiring diagram..  that usually means use the first model in the book, sometimes though it says whether to use the first model the manual is based on, or to use the model supplement before the missing wiring diagram.
I was just looking in the main model where all the detailed instructions are for diagnosing the ignition, and it had this diagram..  but look at the switches..  Might be a misprint..
output2.pdf
So only the last supplement in the manual has switches as you describe, shorting to earth to kill. The earlier models had the main switch killing for run and the kill switch operating earth to kill..  I also noticed that the two relays are different..  one NC and the other NO..
If the main switch wasn't original it would cause problems..
When I check my main switch in the off position the ground pair is shorted together and the power pair is open.  When in the on position the ground pair is open and the power pair is shorted.  Not like in the schematic for the 88 but like the one for the 90.  The main switch is original.  In fact the only thing that I have changed out is the coil and that is because the secondary was open on the original.  This Quad has been in the family since the late 90's and had very little use when purchased.  My father used it to get around our property and plow some snow in the winter so has not had rough use and has need very little other than routine maintenance sinch we have had it.
Almost done with the carburetor just waiting on Amazon and then will try to get back to the electrical.  We will be traveling in a couple of days so it might have to wait until I get back.
Yeah the switch is like the 90 model.
So the atv's plug shape and colour should match the stator's, and they should match the wiring diagram in that pdf "output", where the 90 is the ERA. The wire colours should probably match too, but, I have followed along in here when people have used parts with the right plugs but a wire or two different coloured.
Frame
JY43HPW0*KC000101
Engine
3HP-0000101
Model
1989 YFM350ER W
Moto-4
JY43HPW0*LC024101 3HP-0024101 1990 YFM350ER A Moto-4
JY43HPW0*NA049101 3HP-0049101 1992 YFM350ER D Moto-4
JY43HPW0*PA059101 3HP-0059101 1993 YFM350ER E Moto-4
JY43HPW0*RA070101 3HP-0070101 1994 YFM350ER F Moto-4
JY43HPA0*SA080101 3HP-0080101 1995 YFM350ER G Moto-4
Edited by Mech
Will try and confirm the VIN on the frame but the title says JY43HPW05KC000565.  The wire colors on the ATV side of the CDI match the 1990.  The wire colors on the stator side of the CDI match the 1988 except that the 4 pin connector is missing the grey wire.
When I said the gray wire was missing it is the one on the stator.  The one on the CDI is still there.
Yeah I got that, but thanks for clarifying.
So it seems you must have the 90 electrics. The Vin year numbering protocol has K for 89 and L for 90. We have to watch out though when looking at yamaha model suffix designations because they use W for 89 and A for 90. It gets confusing.
Anyway.. The parts say that from 90 on the cdi and stator gets shared with other Moto-4 and Bigbears. That being the case, and since the stator fits a 91 big bear, this should be the same wiring, and hopefully the specs for diagnosing would be the same. I'll have a look in a 91 bigbear manual later, but if you are downloading(one more post I think), then get the BB as wiell as the Moto-4 manual and have a look. The ignition should be the same, the wiring for the rest of the bike may vary.. not all bikes have brake lights for instance, and the start circuits vary.
BigBear350-91.pdf
Well it remains a mystery..  Your VIN says it's a 89 model, and when I look up parts the 89 stator has the two bullet connections. The wiring diagrams suggest that the big-bear FWW(89) might have the right stator, but when I look up parts online none of the BB have the two bullets.. The FWW(89) Big-bear wiring diagram shows what looks like your wiring according to your description..  Whether you should rely on the 89 BB specs is to be ascertained yet..  Good luck,
FYI. Yamaha designate models years with the last digit of the suffix..
 So the last suffix digit  W is for 89, U is 88, T is 87, and 90 is A, 91 is B, 92 is D.
The VIN numbers use    K is for 89,  J is 88,  H is 87, and 90 is L, 91 is M, 92 is N.
Moto-4 to BigBear.pdf
Edited by Mech
Great reasearch Mech. I have run into this also in the past, parts on bikes that did not match service manuals, never did figure out why, i just chalked it up as factory glitches. The age of these units it still possible they were changed out with different parts.
Bikes of a certain design get released on different continents in different years, and in any particular year they release different version/spec bikes into different markets as well. Also, in motor vehicles at least, and it may not apply to quads so much, countries have trade deals in which a country will assemble vehicles but as part of the trade deal they want to use some local content, so the country supplies some components they can manufacture in their own country.. So wiring looms, seats or upholstery, starters or generators, paint jobs, carpets.. Stuff like that used to be local sometimes.
When we are looking at the service manuals, we need to be sure they do apply to our market or the market the bike was intended for.. before it got re-routed to a different market.. haha.
And, Yamaha are the very worst for swapping their electrics around I think anyway, without any of those market changes !..
Sorry for lack of response but have had little internet the last few days.  I do want to thank you for all your help with this as I had a big learning curve.  Not having good schematics didn't help either.
It has started to work.  I hate problems that just go away on their own. The fact that the pit bike CDI worked from the start leads me to believe that it is most likely one of the interlock inputs.  I suspect that one of the interlock switches was flaky and when I checked it without any movement it would show good and when the motor was rotating it would come and go.  If not that then a bad connection that when disconnected and reconnected.  The fact that the pit bike CDI worked from the start leads me to believe that it is most likely one of the interlocks.
I have not tested it by riding it as I want to go through the brakes and make sure they work good before I do as it has set so long.  Stopping is always a good thing.
Luckly this ATV will mostly be used on my property in Idaho and not on trails so when (not if) this problem appears again I won't be in some remote location.  I also plan to take the older CDI that I purchased and that didn't work and cut the connectors off and wire up the pit bike one to have as an emergency spare.  This will disable all the interlocks but should allow me to get it back to the garage easily.
Ha.. That is a bummer..  That it's started to work !  I hate that too, all the more since I'm a mechanic.
Perhaps now leave it idling and wriggle all the wires everywhere bit by bit hoping to find a short or broken wire that makes the motor die.. Wires mostly only break right where they go into the metal crimped terminal, and they break inside their insulation so you need to use long nosed pliers to gently tug on those ones, and the other place that used to be more common in the past when they used thick wires, was up near the steering head where they flex. Shorts to the frame of course.. anywhere. I'd also check the switches.. The kill in particular is prone to dirty or mud filled contacts. The mud not actually being a dirty contact problem, but when it gets wet it can short enough to cause problems.
And thanks for the thanks. It's my pleasure.
Just an update.  I returned from my trip and finished putting everything back together and it is working good.    Still have a couple of small issues but they will just take some time.  I want to thank you again for all your help.  If I have any more issues with the ignition I now know what to look for as far as what signals to expect.
  • 5 months later...
Interesting read guys. Lots of useful information. I also have one of these 1989 moto 4 350 quads. I bought it back in 1997 and have had nothing but good luck with it until now. Like they say, all good things must end😂. Mine stills starts right up and idles fine but you can’t go past a 1/4 throttle or it starts cutting out like it’s missing on one cylinder but it only has one cylinder. Lol  The majority of the time it sits in the barn and is mainly used during hunting season. It still gets me in and out of the woods but isn’t much help getting my deer out. I have taken the carb off and went through it cleaning everything, replaced the coil, spark plug and cdi. (eBay actually had one) it does run a little better but still the same issue. I also checked to make sure it’s charging and it’s around 13.2 volts. I am an ase certified mechanic (22years) on cars and heavy trucks but know little about these things and information is limited to what I can find online. If anyone has any ideas on this issue I’d be greatly appreciate it if you would share. Lol.    Thanks
It still sounds like a carb issue or some sort of fuel delivery problem to me, some are stubborn and takes several tries blowing through all the tiny orifices also be sure to remove the emulsion tube those tiny holes can only be cleaned with it out of the carb. You have replaced everything else electronic, might check for good ground and maybe do a compression test used rarely could have a valve sticking.
You guys are very good, highy proficient at the new ignition system.  I struggle.  Except maybe a better troube shooting guide wouldhelp me.  Here is one I can understand that is for my Sand Rail '66 VW motor.
    • By cavry
      Cavry
    • By Fonne
      Hi
    • By realpilot
    • By 88bigbear
    • By cfherrman
