Is the spark plug wet with gas after trying to start?   That would prove gas is getting into cylinder.
You can use  starter fluid to introduce fuel into carburetor. just to see it fire...
Wow that's perplexing
If this is an aftermarket carb, sometimes the throttle cable is not adjusted proper for the fit. Make sure the throttle plate is closing all the way and the choke plunger is working properly. Try some starting fluid and see if it makes some noise if it does it will run just have to get the mixture right.
Spark test devices are nice.  I like more tools...LOL
BUt getting it to fire is a great even with starting fluid is good starting point.  This is a 2 cycle motor.  Fuel mixture is important.  Is the  spark plug  'wet' ?
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
