I have been working the bugs out of one of our 2013 Grizzly 700's. I like the power steering more than I thought I would. The electric front diff lock is nice. Fuel injection is adequate even if a little doggy and to me harder starting. Ground clearance is nice.
But dang these things ride like a hay rack. I usually run down around 5psi tire pressure. Have the shocks set as soft as they will go and these things still beat me to death.
Have a 2004 kodiak that isn't much better but then it is not as fancy. I expected better.
Got the handle bars down so they are not yanking my arms out of my shoulder sockets on every bump but still. Disappointed.
My 2025 Kodiak is the smoothest ive been on !! ELKA's coming soon on all 4 corners !! But I have a 2003 foreman which runs great but is not a soft ride LOL I ride a trx 450r sport quad sometimes ride with Work shocks all around Thousand in shocks but not as smooth as the Kodiak
Edited by quadnut20
I suppose I could throw a set of shocks at it. It is super old but also very low hours and miles.
Normally I ride a kawasaki prairie 700. 2005. Solid rear axle, swing arm setup. Even with old hard bear claw tires that things rides like a dream compared to everything else I have been on.
Wouldn't hurt ! I found some Coil over shocks on E bay for under 200 all 4 ! Made a heck of a difference on my 03 Forman 450 !!
    • By HTOverland
    • By Jdeaton011989
    • By TomJulio
    • By Adamb2025
