what is the advantage to having an aftermarket steering stem vice buying an OEM stem?
I bent mine in a roll i took on my first ride in cali. everything works fine, but I'll need to replace it eventually.
In talking with friends, most recommend buying an aftermarket stem....but y?
most factory handlebars are kinda buttery for a reason- so you bend the bars and not the stem. been there, done that. I rather pay $22 for factory bars than $230 for a new steering stem, wouldn't you? That's what is risked when guys put those hard-as-stone bars and clamps on a stock stem. Instead of the bars bending, the stem does. And it ain't cheap! and I don't wanna change any more hahaha Solution: a hardened aftermarket stem?
A hardened stem often bends the front of the frame! yes it got worse LOL and way more expensive.
Think about it before you go and spend $200 on bars and clamps.....you are setting yourself up for a larger repair bill.
:skeptic:
buy a repair manual and do it yourself.
When I have a big project I usually go out and look it over closely, then devise a plan to do it. Take your time. Once it is done, then you will know the shortcuts and be able to help out other folks.....The first time I adjusted valves on a yamaha it took forever, Now it's a piece of cake. Your only other option is to take it to a shop. It's like going to the Doctor or the VET [that's a different rant] nowadays.....:chatterboxn:
that's what I've been looking for, the repair/maintenance/shop manual, but have yet to find any online for the 08 can am ds450
Sorry, cant help you with that, perhaps someone on the Bombardier forum can. they're in Canada, shouldn't be difficult to find in a search..... sorry that's all I have. I will surely look around for you- it's out there somewhere.
      Hello there
    • By Callaway
    • By Gkb
      Need ideas for all aftermarket accessories for my new atv
    • By Frank Angerano
