1997 34' Fleetwood Bounder...$22,900 obo!
By jay41198
By middlebrookgt
By TravisCr
By kiriyaaoi
By jwh
The Kawasaki is a 1989 Bayou 220. Neutral has been found, by pulling the recoil starter, engine turned over the wheels did not turn, so my next step is to put a battery in and see what happens. Oil is half way up the sight glass. The concern I have is the throttle lever is not moving. Suggestions please?????
