By OldATVowner
By hengstserepair
Nuetral: Runs as expected
Lorne
By sandman001
This 2006 ArticCat dvx400 didn't have a reverse cable. I got one and am wondering how it routes? If someone has a dvx400, could post a pic of there reverse cable routing, it would be greatly appreciated. Thanks
By Rockbottom
any ideas how to correct
thanks ahead
By Louznmemind
I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
