Today the President fired the CEO of General Motors ? How can this be ? The Government can now fire a private sector employee ? Oh My God !!! Are we in trouble or what. Better watch out, that means he can fire YOU ! I am still reeling from this. This man is a dictator. What would happen if Polaris got in trouble ? Could the CEO be fired by the President, and then the company operated by the government ? That would spell the END of ATVs and OHVs all together. This mad man has gone to far to fast and must be stopped, or this country and this sport are DOOMED. God help us.
Well, that's what happens when you accept bailout money. GM was run poorly, did not read their customer demands, and let union contracts get out of hand. Heads must roll! Part of the agreement to get MORE bailout for GM, was the resignation of their CEO. I think it's totally acceptable if you want to keep getting tax payer money. That company needs new leadership. If you read about him, he set a bad tone and way of doing things in GM.
Don't worry, he's getting a 20 million exit package.....his 40 year run is through.
If you accept bailout, the government will have a say in your operations.
I think they also need to fire CEOs of the banks who got bailout money to. Got our tax money and won't lead it to people and companies who can pay there bills.
I agree with you BB. I also think that instead of bailout, they should have let GM and AIG go bankrupt. It wouldhave killed teh GM union contracts and the company would have seen some new investors as it rebuilds. AIG is just a Giant that should fall.
It will no longer be called General Motors. From here on out it will be called Government Motors.
That's a good one. Why not, they're covering GM and Chrysler warranties now...
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By jen
      Cannot find out why 12 vdc  4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.   When attempting to run  with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.  I can buy a rebuild kit ~$35 but WTH?
    • By Ejwill
    • By dropze13
      Hi,
      I am recently new to quads and want to learn about the basics and know what i need in case i buy one this coming winter, i am currently looking at quadzillas due to them being available where i live and when looking a better choice than a yamaha raptor as i have a couple friends who rebuilt the engines on them 2 or even 3 times and always had somekind of problem.
      What do i need to look for when buying a quadzilla engine wise and what do i need to check before purchasing one. I heard the quadzillas are reliable and are not a bad quad overall and they do not look bad either.
      Also what are typical problems with the engine and what do i need to regularly check / maintain to ensure i can ride with peace and not need to worry about anything breaking, how much do they also last in terms of miles and ride time ( i know this depends on the use, i will mostly be doing off road and some street use so around the 40-60 mark if they reach that )
      And to service / maintain them what do i need before hand, what oil, what sparkplugs and anything else such as coolant for summer / winter use.
      And if there is any aftermarket parts / components that i can invest in please let me know to explore my options.
      Thank you very much and i appreciate the help which i may get and hope to get into the quad scene soon!
