If you have done anything aftermarket to your Bike,,,,Pipe Etc......You will likely have to Re-Jet....But not before you have done a Proper Plug Chop.....If you are runnin a Stocker.....Then you dont need to re jet....Its Wast of money.....If you do re jet....You DONT need the Whole Kit....Wast of money.....
And yes....I have used them..Worked Fine....
Also,,,,If you buy a new pipe from X Brand Company....They normally Supply you with the "Jet Kit" you will need to get the Proformance out of that pipe....
Edited by mywifeknowseverythin
has anyone used them? do they really make a dramatic improvemnet on performance? are they worth the price and would you recomend them?
thanks
I have used one on my Arctic Cat DVX400.I installed a full system exhaust and an air intake kit on it.The exhaust I bought came with a jet kit;but it was only a selection of main jets.I installed the recommended main jet and at idle the headpipe turned orange hot(similar to right before you apply air on a cutting torch) and it shot flames out the muffler even w/ the spark arrester in:mad:.I ordered a dynojet kit and it came with the main jet selection,an adjustable needle(oem was non adjustable),a drill bit for the fuel screw plug,and some very well written instructions.I installed the stage 2 setting of the dynojet kit.It now never turns colors and runs very well;excellent throttle responce,no bog,the e fan doesn't come on as often,and I'm getting better fuel economy also:biggrin:.I've read a jet kit helps a stock machine but have no personal experience on that.Hope this helps
    • By noticon75
    • By toe420
    • By Callaway
