I got a big problem. Bike will crank only with the throttle pinned all the way but wont rev it just kinda bogs and as soon you start to let off it dies. The bike was running fine prior to this. Its been sitting about a month in the shed. Its getting gas, has fire, 105 psi. This is my wife's bike and she does not ride it anymore so I was getting it out to clean and sell but now this. Any help would be greatly appreciated. :bangheadc:
You may be getting fuel, just not enough. First try tapping on the side of the float bowl with the handle of a screwdriver, you may just have a stuck float. Then try draining the tank and the carb, start with fresh gas. Then make sure the fuel petcock and fuel lines are clean and clear. Next you may want to take the carb completely apart and clean everything. I believe that is a 2-stroke, so while the carb is off, check the reeds. If none of these things help, check your flywheel key and test your ignition components, coil, CDI, stator, plug and wire. Also, 105 psi is pretty low, so that is not helping things any.
  • 10 months later...
There is a vent line on the carb sounds like it is pinched Other ideas at atvwheelin.comin the tech tips:huh:
    • By realpilot
    • By Elk
      2002 Polaris Magnum 325
    • By OldATVowner
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
