So I'm new to the forums tho not to atv's. Anyway, I got a 95 TRX 300ex the other day and it needs some valve seals. The compression is at 150psi, so I assume it has to be the seals that make it smoke. I want to make this thing run better, as it's a nice quad. It's has a racing suspension setup all around, and I don't want to ride around smoking..
Just wondering what would be the best service manual to get for it?
so far short of dropping a ton on a factory manual, i've found the clymer manual to be pretty good, its helped a ton so far, i think haynes is the only other one out there other than the factory one and well from past experiences on a the haynes they dont tend to cover everything. hope that helps
    • By docdoug72
    • By Gunny
      Hope you enjoy the video ....
    • By JMSwed
      Hi EVERYONE
      New member here
