I'm looking for some new wheels and tires for my 300ex. What size should I get. I do not want to loose too much speed and I am thinking of going up a tooth on the front sprocket. Let me know what you think. Thanks.
what kind of riding do you do? if they are for woods/trail riding you could go with the razr 2's or ITP GNCCs....we run both of those, depending on the conditions...
if you do primarily MX tracks, stick with the razrmx.
Wheels, you can prob. get away with regular steel rims...if you compete, go for a more expensive that will help seal the beads, like Hipers or Beadlocks....
Just a thought.
If you go up a tooth on the front sprocket, I would go down 2" on the rear tire size or you will notice a significant drop in acceleration and you will need to work the clutch alot more at low speeds.
yes, I didn't go down on tire size and ended up burning the clutch.
    • By mehim
    • By logray
      Hi all,
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
