Some awesome helicopter footage
By quadcrazy
QUADCRAZY NEEDS YOU!
By mikeexplorer
By spock58
Hard working Grizzly with lots of issues, barely made it off the trailer (and only in reverse)!
By DayBreakJim
20230725_171507.mp4
By Ulfthednar
The Dog loves the runs.
https://youtu.be/tKjBFuHCkM0
