By quadcrazy
QUADCRAZY NEEDS YOU!
By justent_88
Hello, im looking for some input on this situation i have. My 94 Mojave has no spark, and i have no idea what it is. Ive replaced/tested the magneto, the pickup coil, cdi, the ignition coil. Even the key and Killswitch. I haven't tested the harness its self, but i have tried another harness and still nothing. The only thing i can think of is the fly wheel itself. I have found a lot of metal shavings in the fly wheel and have cleaned it the best I could. But nothing happened afterwards. I am truly stumped here and hoping some of yous could shed some knowledge/ideas that could help get this thing to fire.
By DayBreakJim
20230725_171507.mp4
By Ulfthednar
The Dog loves the runs.
https://youtu.be/tKjBFuHCkM0
Create an account
Register a new accountSign in
Sign In Now
