By Kaz
By quadcrazy
QUADCRAZY NEEDS YOU!
By robert63
my cat only has 100miles on it and is in mint cond. since i bought it new in 2009 it has had what i believe to b a carb problem. going down a steep hill makes it want to stall. as soon as u r on level ground its fine.and at top speed it kinda acts like its starving for gas. u let off the throtel a bit n its fine. idels good starts good. hav taken it back to dealer several times. they eithor said it didnt do it or mayb bad gas. my friend says it sounds like the float level isnt rite. any advise would realy help.
By lester
I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
By vickijjones
Just purchased this 4 wheeler in June, now I need to replace 1 wheel bearing, 2 boots (on rear), figure just do both sides bearing & boots. Was told it had 2" lift kit on it.Read some where might need to get different boots since lift. Want to do upper & lower. Any suggestions on how to tell if it's lifted & boots I need?
Create an account
Register a new accountSign in
Sign In Now
