Thanks I gotta get new pics, EX has gotten black frame guards since and the DS has gotten radiator guard, and a water temp guage on the dash and a K&N breather on the case.
right now for the EX im buying a Insane Performance Alum airbox and going to order a moose racing steering stabilizer.
Rancher might be getting traded for a 2003 Z400 but not sure lol.
I need to get new pics of all of them cleaned up these pics are kinda old and dont have everything installed.
Nice, no UTV for me just ATV sport bikes and the one 4x4 but it might be being traded for a Z400
From the looks of your setup you do XC?
Better pics today with my DG frame gaurds only 400 I ever saw with them and my custom X-Factor rear grab bar. I custome did the job since the 400ex dont have a removable wheelie bar, what did I do? I removed it lmao. I installed it in a way that I didnt loose my rear brake light and it looks killer. Most all 400's you see with this done the brake light has been removed.
looks nice dont it lmao I did a bit of riding last night from about 6 till midnight pretty dusty and I didnt come home till 7 am and I spent all day jetting this thing yesterday and again during riding time last night man what a night lmao all nighter with riding and playing some xbox online lol im pooped.
    • By BillR94
      Thank you for your time
      Bill
    • By BruinBeater
      Hey all, BruinBeater here.  Just joined up from the Pittsburgh, PA area.
      I'm the unofficial mechanic of the extended family.  In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage.  Both have a no start condition and have been sitting for 2+ years.
    • By shorty
    • By wjmedic
      right front hub again
