New guy
By BillR94
Thank you for your time
Bill
By BruinBeater
Hey all, BruinBeater here. Just joined up from the Pittsburgh, PA area.
I'm the unofficial mechanic of the extended family. In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage. Both have a no start condition and have been sitting for 2+ years.
By shorty
By wjmedic
right front hub again
