Well picked up a insane performance air box on ebay for $70 got her on today wiring all done. More than I figured several times I was :mad: and :aargh: lmao stupid cylinoid. Somehow it got turned around and was jumping itself but got it figured out and got her all done kinda sorta I have it on and everything inside just gotta clean the inside up a bit.
I removed quiet a bit of extra weight off it and still gotta grind off some of the brackets and such im guessing a total of 3 to 5 lbs just by changing boxes. I removed the box for the case breather and installed 2 mini K&N filters give it a dif look all together and pretty nifty if I do say so lol.
Decals were on it I need to remove them since I dont have anything of it on my bike lol.
Well it cant be hurting. All it is is a snorkle for the transmission and its just filtering air going into both the transmission and the carb so neither is getting raw air. Most atv's just have a hose I just dropped a big plastic box off it and put two filters. Dont think it will help but it wont hurt it either and it looks cooler lol.
I will get pics been working on one my the laptops all day its being a pain and I got to finish getting the dual wileyco exhaust on the DS
Agreed, the two little filters look cool and I wouldn't think they are hurting anything. However, you will need to check the inside of the crankcase breather occasionally and make sure it doesn't get clogged with oil.
Im all over it if it becomes a problem I can run my old stock breather kit dont think it will. The DS has been setup with a single on the crank case for awhile now with nothing wrong so far.
And sorry about not getting pics. My wireless router is giving me havoc and its been hard to do anything online. Thought it was the laptop after doing everything possible to fix it moved farther down the line to the router now its just getting the right time to get online.
    • By jay41198
    • By Arizona
      Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
      Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
      too blury and cant tell wire color. Just too small. Thanks Az
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
      I pulled out my Big Bear needed to do a few things probably havent been started in a year. Gassed it up charged the battery started right up. I have been using it around the property for this and that. Went to hook up my trailer to pull up to the house while it was idling it quit. Went to start it turned over but wouldnt start. After trying a few more times lost all power. Pulled it up to the house with the John Deere, the first thing i checked was the Universal fit soloenoil from Amazon and it was only a 10 AMP fuse so it does not universally fit the big bear it should be 30 AMP fuse. At the time i remember noticing it but forgot, at the time i had other problems like wiring harness being in a box stuck engine and no spark. when i bought it, yeah i know, thats one ishould have walked away from, but if i go to the trouble of hooking up my trailer and going there, its following me home.
      Thats old news, i still need to check it all out see if it lost spark and see if the starter shorted out it was acting kind of sluggish, i replaced the fuse with the spare 10 amp and blew immediately. I will try a 30 and see what happens.
    • By mga
      So, i go to change the oil in my 2k Y 400 BB and, without reading what types of oil to use, i just put in 10w-40 motor oil.....then i decided to read exactly what type of oil i should be using. Apparently, the ATV oil is designed to also work with the clutch..lol...which is probably  why i was having a few issues going into the gears, or, maybe losing 1st gear going down a hill. Ok, now that i got educated i bought like 6 quarts of the "special" oil required.
      Now, my second issue is it was hard to start for some reason. Usually it fires right up. So, once started i brought it up to the garage and removed the seat, thinking maybe the battery was weak from sitting. Nope...12.5 volts, but.....a mouse decided to build his nest right on top of the battery. I cleaned that all out, but, when i went to start it, the solenoid clicks and the starter just spins. UGH. One thing after another. No wires were chewed thankfully. Just kind weird the starter would do that all of a sudden when i messed with the oil.
      Do i need to pull the starter now and check the bendix thing? It spens real nice, it just won't engage. The wrong oil wouldn't do that...would it?
