Guest Fox300exchic
Last week U.S. District Judge James Robertson ruled that the government must change the nation’s currency in order to give the blind and visually impaired a way to distinguish among the bills. According to Robinson, the currency violates the Rehabiliation Act which prevents discrimination on basis of disability in government programs. Noting that the US is the only country that prints all paper currency in uniform size and color, some suggestions made by Robinson included making bills of larger denomination larger in size, color distinguishing features, or raised numbers. The govenment was given ten days to appeal the ruling or thirty to start working on the problem. While I do believe that we could all benefit from this program, as there have certainly been times for one reason or another I could no longer see well enough to distinguish the numbers, is our money really discriminatory or is it just another example of how life is sometimes unfair? Is there even a difference?
Read more »
  • 4 years later...
    • By marcosphoto
      The AMA U.S. ATV Motocross Team of Bryce Ford, Joel Hetrick and Brandon Hoag dominated in the Czech Republic at the 2024 Federation Internationale de Motocyclisme (FIM) Quadcross of Nations. It marks the sixth time that the team has secured a global championship since 2017.View the full article
    • By Slitzer
      How often do you change oil in front/rear diffrentials and gearbox?
    • By afa913
      Do the small 50cc's have a way to set the speed. Im wanting to get one for my kid and i need to set it to go slow. I know the chinese knock off fourwheelers do but i dont really want one of those
    • By blasirl
      I have inherited an ATV and I think it was purchased in  KY, but I am in WI.  Is there a way to do an online search using the VIN or what have you to try and find the last registered owner so that I might try to get the title?
