Hi All,
i have a yamaha beartracker which is not charging and I'M looking to test the elecrical output fom the stator/rotor to check if all is well in that department. just wondering if anyone can tell me what readings for voltage/current I should be getting if the electrics are healthy? also could some one direct me to a wiring diagram on the net or post one if possible? Any help would be greatly appreciated.
Regards
Chrisok1
output charging rate should be no less that 13.5v to battery
if not check stator continuity to ground an to each other
no coutinuity to ground and continuity to themselves are good
if okay check stator out put should be around 20 acv at idle and about 75acv at 5000rpm
if good replace regulator
if not good check stator and fly wheel
Thanks for the help yimcyco,
traced the problem back to the stator/flywheel so i pulled it off to check it out. Turns out the owner had let it run low on oil and the stator windings at the higher level have burnt out so I'm on the trail of a second hand stator now. Hopefully be able to source one soon.
Thanks again for the help.
    • By RadRob
    • By fwsamm
