I have a honda rancher es 4x4 and the electronic shift has quit working and when ever i turn it on neutral just blinks. Could this be the angle sensor has gone out ?
Please include the engine size in your next post so I can add it to the thread title. I am not sure what you mean by angle sensor, but I do know that there are solenoids and mechanical actuators that could be malfuntioning. I would first try locating the solenoids responsible for sending power to the actuators. There will probably be one for upshifting and one for downshifting. If you can determine which one controls the upshift mechanism, try manually applying power from the battery to the lead that feeds the actuator. If it doesn't shift, the actuator is likely the problem. If it does shift, then try applying power to the low current input wire that activates the solenoid. If that makes the vehicle shift the problem is between the switch and the solenoid. If it does not, then the problem is likely the solenoid. A repair manual will be helpful, if not necessary, either way, I recommend getting one.
BTW, I am moving this thread to the Honda ATV forum.
yea i just bought the 4 wheeler and the guy told me that the angle sensor was bad i just wanted to check and make sure that was right i need to get a manual but if this helps you any when you turn the key on neutral blinks 3 times.
Once again, please include the engine size of your machine. I do have a friend that has an '04 Rancher, I can check and see if his does the same thing when you turn the key on. I will probably see him tomorrow or saturday.
alright thanks i believe thats whats wrong wirth it i have had alot of people tell me the angle sensor is probably bad
The neutral light blinking is giving you an error code. I have read many other post with similar problems and it was due to the angle sensor.
yea i went ahead and ordered one i believe thats whats wrong with it to i just wanted to get a secong opinion before i bought the sensor because i cant return it once i install it.
i have a 2002 rancher 350 es that has had several shift problems and it usually leads to the angle sensor or the electronic shift actuator i have had these problems several times and had to replace both of them ..
    • By Cj Winds
    • By OldATVowner
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
