went riding the other day. All went well loaded atv on trailor and when i got home it would not pull ,foreward or reverse...Had clutches replaced and same thing is happing need help. I just dont know what it could be...
oil the chain for starters.
if that's OK then adjust the clutch.
we once had a 400ex in the shop and the chain was so tight and dry that we had to pick it up with a forklift to move it! chains tighten up as they dry out.
should be lubed every time you ride it.
    • By oztrax
      MAX 4 6X6 2008
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      What a great week to ride !! Im semi retired and plan on riding this week !! Who else is riding and where !!
    • By mikeexplorer
