OK im looking into buying a 03 polaris sportsman 600, the guy said 1 of the connecting rods was going bad (he has the engine down) and i was looking on the parts diagrams and it doesn't seem like you could pull it apart to replace it, what the hell!!! And there doesn't seem to be any replacement parts on the net. Babbits has the diagram
Looks like the crank is not rebuildable, you may need to buy a whole new crankshaft. The counterweights on a non-rebuildable crank can be machined to accept a push though pin, but that is probably more trouble and money than it is worth, plus you would need to find a rod that would fit the pin you put in and was the right lenth as well. I would just assume that it needs a new crankshaft.
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
