my big bear is smoking. a guy i know said i when it does that and i just replace the rings it will end up doing it again. he aslo told me i would need another piston and have to get it bored. would just replacing the rings and getting it honed fix the problem or what? any advise is appreciated thanks
Honing and new rings is a quick fix. I would do as your friend recommended, bore and new piston, rings, etc. It will already be apart and for the extra cash $150 or less it will last longer than just new rings.
If you just replace the rings and hone the cylinder it may quit smoking, for a little while. There's no telling how long it will work. If you want the long term fix, bore it, hone it and put a new piston and rings. While you have it down it would probably be worth a valve job or at least replace the valve seals.
Around here it runs about 45 dollars. To cut the valves and the seats you have to have the correct machines. You could probably get away with just lapping the valves if your in a crunch for money, but it will require knowledge on how to properly lap valves.
I agree with Yamaha468, it would be best to address the valves as well, since it is just as likely that worn valve guides is the problem. What year is the Big Bear? I merged your two threads since you posted the same question twice.
Edited by DirtDemon
its a 1994 yamaha big bear 350 all time 4wd. atleast the guy i got it from said he thinks its a 94. ist there a way i can find out for sure what year it is? cause i looked for a sicker on the frame but its not there.
i know its not stolen i got it from my friend i grew up with i ended up talkin to the guy who they got if from which i found out was my friends grandfather. he used it on his land to ride around on. but he told me all about it. and its a 94. i got my cylinder bored. it was bored alread to .75 and the yamaha dealership said that it was so worn out the cylinder wasnt round anymore it was egg shaped. so the bored it to 1.00 now i just gotta get the piston and rings and ill be set. the guy at the dealership told me it would be best to open up the right side of the case and drain all oil out and make sure theres no dirt or grime sittin on the bottom of the case. so hopefully ill have it running again.
    • By BruinBeater
      Hey all, BruinBeater here.  Just joined up from the Pittsburgh, PA area.
      I'm the unofficial mechanic of the extended family.  In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage.  Both have a no start condition and have been sitting for 2+ years.
      I have had my new tires for a while, chronic procrastinator, decided it was time to get them mounted up. Against my better judgement i decided to mount them myself.
      I got one of these Harbour Freight manual tire mounting machines, mounted it to a half pallet to make it more portable. Very impressed with the quality and amount of tools that came in the kit for a low price point.
      The bead breaker worked very well, i wasnt sure it would be able to do it, i think these tires are original to the bike its a 2004, but with enough lube, mothers concentrated car wash straight, it finally broke the bead.
      Tire fit very well on the machine and it tightened down good.
      The extra long pry bar that came with the kit worked well to get the outer rim of tire off.
      Half way there, half way there no issues, then it got serious.
      I pulled and i tugged had 3 prybars working this thing and it wouldnt budge no matter what i tried it would not come off, until i got the grinder out and cut it off. Im sure most of you see what the problem was. I didnt notice it until i was too far in to change direction. On this particular rim the tire goes on and off from the back side of the rim, not the front like what i was used to. The back side is the low side. Plus to add to the problem tires were old and not very strechy, i have a greater respect for how well these ATV tires are made with well reinforced sidewalls, even with the grinder it took me a minute or two to cut through it, of couse i was being very careful not to nick the rim. Anyway the HF machine worked well and the tire is off, hopefully the next one wont be this bad. Lot of hard work for an old man, glad i can still do it.
      Now for the fun part , cleaning up the old rim, years of stop leak and slime caked on the inside, that stuff dries hard, the little Milwaukee is good for getting into tight spaces, but wasnt quite up to the task.
      Needed a few more RPMs.
      Old rattlecan paint just flaked right off. Now time to decide on a new color, tired of the boring gray. More to come!
    • By Atomusthenes
    • By shorty
    • By Ejwill
      My 2007 trx500fe is smoking at Idle and while running through the gears. It’s white to grey smoke not black. Give me the bad news like top end rebuild or something. I know it can’t be something easy. Any help will be appreciated.
