By HoldenBoy
By WyattLemke25
Having problems with the battery draining while riding. It has a new battery, it does have eps, a lightbar and a winch. Can ride it for an hour or more just fine, but eventually the battery runs down to the point it can't keep up with fuel injection and it'll sputter, limp, and die. It also throws codes for the throttle position sensor. I'm not sure if that is related or not. Any ideas?
By cervenakrava
Hi,
New to ATV repair but willing to learn and get my hands dirty.
We start the atv and even with a good battery, it will drain it very quickly and eventually the atv shuts down. Checking the battery afterwards shows significant drain on it.
Would this be a shot alternator? Some electronics module?
Thank you kindly. Just need to be pointed in the right direction and then with a repair manual will get to it.
Cheers
By Tpipes
I have a 2002 Arctic cat 300 4x4 that died on me. I was headed out ice fishing and got caught in a snow drift. I got off and was pushing it while using the throttle, I was making good progress until I heard a "click" then it died. ATV hasn't made a noise since. It had fresh oil, new battery, and a fresh rebuild on the carb. I am hoping someone can help me get it running again or at least give me a starting point.
By ray desocio
I was out plowing just now and I rammed a snow bank at moderate speed and the machine switched off. Then wouldn’t start. It would crank but not start. I pulled it back to my garage where it will now start and idle but then cuts off. I can restart it but after a little while it cuts off again. I can rev it up while it’s running but will die mid rev.
I checked the voltage and while running it shows 14 volts, so it seems the charging circuit is ok, and the battery is sitting at 12.5-13.
where would be a good place to start troubleshooting? I’m not really sure where to start.
any help would be greatly appreciated!
