New ATV regulations proposed
By jen
Wow...I packed a small soft side cooler with an ice pack at -4 F and inserted my Type K thermocouple sensor inside so I could monitor the temperature without opening. After 3 hours the inside temperature was 60 F...OMG! The ice pack was solid frozen. Standard temperature for safe storage is < 40 F. What I found by asking was that there should be no air space in the cooler. Packed with Ice preferably ice from connivence store (normally 0 F of less). Food should take up short day trip1:1 ratio.
Good coolers are expensive.
By DexKing
Good day everyone!
I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
By Rockbottom
Any body have a part number for replacing the safety interlock on the left brake so you can start the engine with the brake handle pulled and in gear
or how to bypass this function so you can start in gear
By Gretgest
I’m shopping around for an enclosure for my Hisun 500 and have already come across a few different brands. I’ll put together a post soon with everything I’ve found and some links. For those who already have one, how do you like your setup? I’m especially curious about options that include Hisun 500 soft cab enclosure upper doors since I’ve heard double-stitching and good fitment make a big difference. Ideally, I’d like detachable doors and a zippered rear window so it’s easy to open things up during the summer.
By mans
Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
