Guest Fox300exchic
I got a stupid jury duty notice for next month!! I just got one about 4 months ago and luckaly my number wasnt called. Now I got it again. Hopefully it isnt called again. Wish me luck!
What is so Wrong with Jury Duty???? I love it!!! Last one I was on was for a Week and a Half... It is an opportunity for you to Serve your Community and do someone Justice....;) I Can see however, if your not getting paid for it....That must suck....I Still get my Full 40 hrs.... I just love Gov. Jobs:D
Guest Fox300exchic
It wouldnt be as bad if I didnt have to find someone to watch my son.
Guest Fox300exchic
It isnt till next month but Ill be sure and let ya know. :D
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
    • By mga
      So, i go to change the oil in my 2k Y 400 BB and, without reading what types of oil to use, i just put in 10w-40 motor oil.....then i decided to read exactly what type of oil i should be using. Apparently, the ATV oil is designed to also work with the clutch..lol...which is probably  why i was having a few issues going into the gears, or, maybe losing 1st gear going down a hill. Ok, now that i got educated i bought like 6 quarts of the "special" oil required.
      Now, my second issue is it was hard to start for some reason. Usually it fires right up. So, once started i brought it up to the garage and removed the seat, thinking maybe the battery was weak from sitting. Nope...12.5 volts, but.....a mouse decided to build his nest right on top of the battery. I cleaned that all out, but, when i went to start it, the solenoid clicks and the starter just spins. UGH. One thing after another. No wires were chewed thankfully. Just kind weird the starter would do that all of a sudden when i messed with the oil.
      Do i need to pull the starter now and check the bendix thing? It spens real nice, it just won't engage. The wrong oil wouldn't do that...would it?
    • By killerklown
      I received an additional parts engine with a 220 Bayou I purchased, but I believe it's a couple years newer than the ATV, Is there a way to decode the engine serial number like we can with VIN numbers?
