mywifeknowseverythin's new hillshooter
Similar Topics
By FalloutBoy
I can't find a diagram for my Can-Am, all the diagrams have different color coded wires and are missing the necessary parts to fully re-wire my Can-Am. Any help would be appreciated
By glencam
Hi everyone new to this forum so thanks for taking the time to read my questions. I have an older 88 Big Bear 350 and it wont go into Hi range ....well I think its Hi it wont go into it may not go into low range it will go into reverse when i shift the shifter it moves all the way back (i removed the pin and manually shifted it ) forward is reverse middle is low and all the way back is hi but when in hi position its like its in N no forward movement of the machine in any gear. I did get it to work once but then shifted to reverse to get it out of garage and the problem returned.
Where is the Hi/Lo gears actually situated? by removing the right side cover to expose the clutch will I gain access to the shifter?
The "Middle Gear" housing on the other side (left) does it take gear oil ?
thank you
By BlueBowtie
Is it possible to put a motor from a big bear 350 into a timberwolf? Reason I ask is that I have a timberwolf with a bit of a rod knock, and I have big bear with a bad rear end and axle with a good motor. So, is it possible?
By 86096
I have recently acquired a 1985 Suzuki lt230ge quadrunner. It has an automatic clutch. How do you ride it. do I select a gear and then give it gas and it will go? What about downshifting? I don't want to jump on it and go and risk busting something on this old rig. Any advice would be appreciated. Thanks in advance!!!
By Thom592
The 400Big Bear I'm working on, had a couple issues. Starter is spinning backwards.. What would cause this?
The brushes are in place and I could find no burnt marks inside..
Any Insights would be greatly appreciated.
Gallery Images
